- 10,350
- 94
- 48
- Meadows of Dan, Virginia
See what gauges will do to you.
Otter,Otter said:Hello,
Here is my addition to the pyro mount fest!
What numbers is everyone else seeing post-turbo thermocouple?
I see about 1000F during a hard climb!
I'd be pretty nervous about running at 1000F with a post turbo pyro. Everything I've read says the MINIMUM difference between pre and post turbo pyros is 100F, most seem to think 200F-300F is more typical. So at 1000F post turbo, depending on how close you are to the turbo outlet and whether yours is a temperature balanced pyrometer or not, you may be running way too hot at the turbo inlet.Otter said:Hello,
TXSG_19_commo said:This morning I mounted a pyro 2" downstream of the turbo outlet. Is there a big difference between 6" and 2"?
It was a bear removing the clamps and that short pipe, they have not been off since 1991. Got the nipple or whatever it's called TIG welded on, and put it back together. I pushed the laden beast (20,000 GVW according to the scales) as hard as I could, and had a hard time getting 900 degrees out of it.
Only at 55 charging up a hill, and decelerating despite having the pedal to the metal. I suppose I could turn it up 1/6 turn and see what I get. Maybe there is alot of difference in 100 degrees?
I noted that the pyro guage itself, disconnected, sits at 50 degrees. normal? Connected to a cold engine, it does not move any, so maybe that is right. It's all new stuff.
On level road, 55, stayed around 700. Surprised how fast the temp decreases when the fuel is let off at speed.
