Jakob
- 5
- 18
- Louisville, KY
I can't afford it right now, I was just curious.
What are the correct temp and boost ranges?I used the Hewitt gages also. They were great to work with. The guy I talked to way back when said they had never had a deuce application before. I gave him the temp and boost ranges and he figured out the best gauges for the ranges given. I used 2 thermocouples for the EGT gauge. The only power needed for them is for illumination. They even supplied the 24v bulbs. I highly recommend them.
How are you doing on this, Gimp? I'm really close to buying a Boost and EGT gauges, and was curious about your results.I will install all the Hewitt gear and get a baseline of results, then install the SW gauge and see if there is a big temp change. If not I will run the SW gauge with the Hewitt probes and wires on my other trucks. Hewitt
