Questions on Wiring APC Dome Light.
Dozer11B
Alabama
I'm not an electrical guru, so please bear with me.
I found a lot of posts/threads where folks have installed these lights, but they didn't get very specific as to how they went about it.
From what I have pieced together it seems 14ga wire was used and some folks said a 15a inline fuse would do it. Is this correct?
Would I wire this into an accessory slot in the fuse panel under the dash? I understand there are both 12 and 24 volt slots under there so I would test them to find out.
Thanks in advance.
1,824
The housing needs to be grounded. All of the APC lights I've encountered had 24V bulbs. You can either switch them to 12V or tap the one 24V fuse in the bottom slot of the fuse box. I have the one in my M1008 running the 24V side.
Dozer11B
Alabama
Ok looking at the -20, it appears that is labeled as "12. 10 amp/28 v (Voltmeter) Fuse". The accessory slot next to it goes to that fuse correct?
Thanks.
ETA: Pic of how I'm gonna mount it. Ground should be good I think.
Dozer11B
Alabama
I ran it to the power block for the radio tray
That's the "radio terminal board" next to the fuel filter assembly in the -20 correct?
I plugged the wire into the "12. 10 amp/28 v (Voltmeter) Fuse" spot on the fuse block and the light will only come on with the headlights and the brightness adjusts when I turn the headlight knob to adjust the gauges, lol.
taylordc15
Sale Creek, TN
No, mine still had the radio tray in it. power for it comes in just aft of the passenger side doorMVC-010F.jpg you can just see the buss bar below the tray.
Dozer11B
Alabama
Yeah I don't have that buss bar. I get 24v to the one under the hood behind the battery, so I think I'll just wire it in there.
Thanks.
ETA: Wired in to the buss bar under the hood with a 15a fuse and working good. Thanks guys.
