Radiator Hose Heater
SasquatchSanta
Northern Minnesota
Anyone out there have any experience with installing a heater in the bottom radiator hose on an M35?
I've already got a freeze plug heater but want to install a hose heater to help starting and shorten the time it takes to get the defrosters working.
The bottom hose appears to be close to the fan belt/s --- was just wondering if there is enough room?
I would also be interested in knowing the brand and part number of the heater and the hose size.
Any info would be appreciates.
1,814
I recovered a recirculating heater off a deuce several years ago. It was tapped into the heater line. Never did see it work but the idea looked pretty cool. Cranetruck has it now!
red devils dude
Ft Campbell
you could get a freeze plug heater Zero Start makes one for the deuce engine
G/D4800 (7.8L 478 CID)
Part No.3500025 Watt 1000 Volt 120 Diameter 2" Type Freeze Plug
SasquatchSanta
Northern Minnesota
As stated in my original post --- I've already got a freeze plus heater but want to ALSO install a bottom radiator hose heater. I'm concerned about clearance between the radiator hose (heater) and the fan belt. Just wanted to know if anyone had ever seen one installed.
