rebuild heads or new motor?
deepseeman
San Diego, ca
My head gaskets need to be replaced and I have quotes from 1200 to 2500 to get it done. is it better to just buy a rebuilt motor or do an upgrade to a 6.5? i dont have the time to do it myself or I would try.
does anybody know someone in the San Diego area that works on these beasts?
I would rather support someone from here first then use a no namer out in town.
Shop Rat Fab
Detroit, Michigan
To answer correctly and for us to give our opinions we need more info.
Are you sure its the head gaskets and not a cracked head or block?
High mileage on the truck or not?
Cost of reman engine and install would be more than head gaskets.
No need for a 6.5 upgrade unless you have one. (My opion)
ralbelt
9
West Warwick, R.I.
I replaced one head with a new one, original was cracked, and had the other resurfaced and valves inspected and recut or replaced as needed, tear down was 2-3 hrs and reassembly about 6-7 in 30 degree weather. I had never done one prior to.
With the TM's handy it's a relatively easy job.
deepseeman
San Diego, ca
appreciate the advice and input. I am having the heads done by a buddy's shop. 1k total unless head needs replaced. actual mileage on motor was unknown. my guess around 200k. i was losing coolant and have a new radiator and hoses with no leaks. I had bubbles coming from between the block and the head. I just wanted to get on it before it got to bad.
Blood_of_Tyrants
10
Lebanon, TN
If this guy is charging you $1000 just to replace head gaskets, he isn't your "buddy". He is charging you $1000 for $100 worth of gaskets and 6-8 hours of labor.
****, you can buy a HMMWV pullout engine that runs for $600.
JUNKYARDJOHN
somerset ky
I bought two from G.L. for $150 each. The shipping cans they came in were 540 lbs each & worth more than that. I plan on making a woodstove for my shop out of one & an engine test-running stand out of the other. :beer: John
