ssgtwright-usmc
- 2
- 0
- Hawaii
I will be attempting in the morning, by myself to remove the fuel tank from my M1008.
I plan on cleaning out tank and replace the fuel sender unit since it gives me bad readings and plus I think the sock is clog with gunk.
My truck does have a 4 inch body lift so removing the tank from below is not the proble.
My problem is that I have to disconnect the fuel lines and the sender wire from the tank before I can even lower the tank to the ground.
Since I will be working by myself, how can I reach the fuel lines so that I can disconnect them.
I cant even get my hand between the cab of truck and the bed to reach the sending unit.
If I had the right tools like a lift or even a few friends to help me I would remove the bed.
I dont have thiat as a option.
So how can I reach the fuel lines now to disconnect from sending unit before lowering the tank off.
