resistor mod/elimination
SGTskully
Gothenburg, ne
I just did the mod to get the GP relay to 12 volts, and it was pretty easy. If you dont want any splices or cutting, ect.
disconnected batteries
removed wire from the 24volt Buss. (it has a fuseable link in it already)
removed wire from the GP solenoid
Remove resistor pack mounting plate and remove resistors
take 24v wire w fuseable link and connect large ring lug to solenoid, and small ring to 12v buss.
Done deal
the boot slips off the other wire and onto the fuseable on without cutting.
then put the resistor mounting plate back or leave it out. You decide
I put mine back to hide some more electronics when I add them.
