Restoring rusty chains
cranetruck
92
Meadows of Dan, Virginia
The original coating is disappearing from these chains and I'm wondering what the board thinks about re-coating/painting chains.
Is there a dip or a "converter" that can be used?
BillIdaho
Caldwell, Idaho
I learned a trick a few years ago on how to clean and shine up a rusty chain.......Get your 4 wheeler or dirt bike out, get a rope or another chain hooked up the rear of the rig, attach the rusty one to that, and drive around for awhile on a gravel or better yet--sandy road. (Dirt roads will work, but it takes a lot longer. If you don't have such vehicles, go to the local dirt bike area, and give a kid 5 bucks to drag it around.
BFR
Rocket Surgeon
2,330
42
North Georgia
I have kept the chain on my front mounted winch painted with the same paint as the truck. I don't know if it is "correct", but the areas that rub keep themselves clean and the paint protects the rest.
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Bjorn, electrolysis might be an option. I would think that a light sanding and a good rust converter should do the job. Chains are a pain to keep in good condition.
1,823
Dragging chains on my sandy street are usual business here. As a matter of fact, it works pretty good on rusty oxygen bottles too!
BFR
Rocket Surgeon
2,330
42
North Georgia
If you had a truck like mine you could store them on a pallet underneath and the slow, but steady stream of petrochemicals landing on them would prevent any rust issues.
1,823
That resembles my truck. If I have a weed problem on my gravel driveway, I park the M108 there.
timntrucks
133
Ponchatoula LA
one quick way is to dip them in muratic acid . in a few minets they look like you sand blasted them. you will have to use a neurtralizer afterwards and then immedialy drop them in oil as they will rust before you eyes... :-D
Chinookpilot77
Enterprise, AL
Get a 5 gallon bucket with a lid, insert chain and cover with sand...roll it around for a while.
This is the same way a person would have polished chain mail 500 years ago. Works like a charm.
swbradley1
Modertator
1,911
Dayton, OH
I drag mine behind my big mower when I do the big fields. Cleans 'em right up.
I like the idea of sand in a bucket. You could actually take a barrel and place it on rollers tilted at an angle and have a motor drive the barrel like a tumbler like a cement truck.
davesgmc
132
Mclouth, KS
they had 5 gallon plastic buckets with lids 500 years ago? wow that is old technology!
M543A2
15
Warsaw, Indiana
Bjorn: Hello!
Can you find a zinc plating facility in your area? They can clean the rust off the chains in a bath, then plate them with zinc plating for you. They might recommend "barrel" plating them instead of rack plating them to get better coverage. The zinc plating will keep them looking nice for several years.
Regards Marti
swbradley1
Modertator
1,911
Dayton, OH
The least you could do is warn someone before you post something like that. I could have spit soda all over the place from laughing.
wideload
Stockport, UK
I have found the easiest way is to put the chains in a cement mixer with a bag of sand for a couple of hours, they come out like brand new without any localided damage which blast or acid cleaner may create.
Chinookpilot77
Enterprise, AL
Unsure if you're making a joke at my expense or just plain being a smart ass...but nowhere in my post did I say "plastic" They absolutely had these little contraptions called "wine barrels" made of a very old technology called "wood".
oilcan
Ohio
The gravel road approach is certainly tried and true. I've done it myself several times, but it's best to keep your noggin screwed on straight when you try it. Also, some local LEO's could frown on the practice. I don't know if it'd be better to ask permission or forgiveness for something like this.
Sidebar... I'm glad to see a few people still have a sense of humor.
