riggermedic
- 31
- 28
- Phoenix AZ
Hello all, in June 2015 I bought a 1986 M1009 with 65k miles. As far as I can tell it is in close to perfect original condition. There are no screw holes, repairs, welds, and very minimal rust.
The guy before me just had a lot of work done including 5 new tires, a new steering gear box, tinted windows (a must in AZ), slide back rear windows, an electric fuel pump, and removed the stock fuel filter, but replaced it with a tiny one along the frame rail.
The concerns I had was the lack of a real fuel filter, that strange wire just hanging out above where the fuel filter was, and the rear pinion seal was leaking.
I found all the info I needed and a bit of a debate on how to change the pinion seal, I opted to do the thread counting nut marking method. 3k miles later and no issues. First repair done (sorry no pics).
The last owner replaced the ignition key, but not the rest and the passenger door lock was broken, so once again I consulted the forum found many pics and readable instructions on how to change the lock cylinders, I did all four and in the process of changing the rear window crank lock discovered that the previous owner had recently replaced the entire guts to the back window. SCORE (sorry no pics).
a little bit of searching and I found more info on the 24 to 12 volt resistor bypass that was apparently done. no worries about a dangling red wire (to be removed at my convenience)
Coming soon: tiny tach, spin on fuel filter, back up lights, front grill light bar, new battery cables, and a super duper special ammo can center console with enclosed stereo, scanner, and SSB CB with all detachable bulkhead connectors, inverter, and roof rack eventually.
