Rockwell Axle top plate question.
acme66
Plains, Montana
I will not be able to open my pdf manuals until I get home, something I didn't think I would need just to deal with a leaking top plate. In the picture the screw driver is pointing to a threaded hole that is not totally covered by the top plate. It leaks, a lot. Am I supposed to have a plug in that? What is supposed to keep that from leaking?
Ken
acme66
Plains, Montana
Ahhh, the cover isn't symmetrical, it is a little wider on one side than the other. I think I answered my own question. It got spun around at some point and I just kept putting it back on like I found it and being frustrated at the leak I couldn't stop. Brain fart.
Ken
EDIT: Nope it was just my gasket that made that one side look wider. I might have to take another apart if I can't figure out what is supposed to be filling that hole. Makes me worry I will just end up with two leaking axles...
Tow4
674
Orlando, FL
Look at one of the other axles to see what's there, they are all the same.
acme66
Plains, Montana
Alright some lawn-side sleuthing uncovered the issue. When I tightened it down the gasket on that side slid inward about an 1/8th of an inch leaving that hole covered only by RTV with no backing. That is why it held for a few 100 miles or so then started leaking. Gear oil worked its way under the RTV and the axle pressure pushed it out. I think with some RTV grey, a wider gasket and more drying time before installation we will have this licked.
Ken
