ROVIS / AN/VIC-3 system (Intercom System) NEED HELP
Dmbuhan
I have the ROVIS / AN/VIC-3 system (Intercom System) I want to install it in my yamaha rhino.. I have the power cord but the end is a weird connector. One end goes into the Mater Control Station and i dont know where the other end goes.. So i cut the connector off and hooked it up to a battery charger. it works!! but when i go to put it on the battery of the yamaha rhino It does not...... Can anyone HELP ME PLEASE
OPCOM
Dallas, Texas
It is probably 24 volts, what voltage is the Rhino? Also, don't run the thing on a charger, they have unregulated anf often dirty power, you can cause damage. The VIC-3 is pretty rare. Pictures of the system, connectors, etc. would help.
Dmbuhan
Pictures ROVIS / AN/VIC-3 system (Intercom System) NEED HELP
The battery charger on the jump mode runs at a 12.06 voltage the Rhino battery is at a 12.99 voltage.. why wouldnt it work on the rhino.. Heres Some Pictures The video will be up on youtube ill send the link later
Dmbuhan
Heres the video http://www.youtube.com/watch?v=3QwqlKSo_Ec
Dmbuhan
RE: Re: ROVIS / AN/VIC-3 system (Intercom System) NEED HELP
So My dreams are shattered. theres no way i can hook it but unless i have a 24 volt battery??????
Dmbuhan
Re: RE: Re: ROVIS / AN/VIC-3 system (Intercom System) NEED H
maritimer said:
or get a converter thingy to step your 12v supply up to 24v
can you tell me where to get one ?
Jake0147
Panton, VT
Re: Pictures ROVIS / AN/VIC-3 system (Intercom System) NEED
Double check that- If that were accurate, when it were hooked up it would discharge a fully charged battery down to about a twenty five to thirty percent state of charge. It might be that while it's hooked up and boosting, but the open circuit voltage is probably sixteen or seventeen volts, it'll drop lower quickly as the current increases.
Even at the right voltage, battery chargers eat electronic equipment. It would be a big shame to see this system wrecked, probably beyond repair, simply by a misunderstanding about how battery chargers work.
A converter is in order. That, or depending on the draw and the usage it might be possible to do it "flashlight style" with a couple of small (or large?) batteries, but I'd go for the converter.
maddawg308
793
Appomattox, VA
RE: Re: RE: Re: Pictures ROVIS / AN/VIC-3 system (Intercom S
Not familiar with the VIC-3, only the older VIC-1 series. That looks pretty cool and high tech. Neat setup.
mutt_kahuna
10
M151 country,Nevada
mil intercom
For an in-expensive way to get a 24 volt battery,I once made a small portable jump box that was made up of a small plastic battery case and two 12 volt motorcycle batteries wired in series...I used it as a slave when my M151 batteries were low....to recharge, battery tender makes a 24 volt trickle charge...maybe this will help...I sold that M151 AND the jump box so I dont have any pics.. ..ED
Dmbuhan
Re: RE: Re: Pictures ROVIS / AN/VIC-3 system (Intercom Syste
CanonNinja said:
Dmbuhan said:
Long story.. Why? is it a good system?? heres a vid of it http://www.youtube.com/watch?v=3QwqlKSo_Ec
do tell, because that's the new latest-and-greatest
Would you believe me if i told you Fort Monmouth (New Jersey) Threw Them away, Meaning in the garbage.. I work in a garage transfer station and they was cleaning house I THINK thats how they got there..
CanonNinja
Houston, Tx
go find me another one :D
And I dunno if you're going to be able to get 24v on the rhino without adding 2 more batteries for a separate system
Dmbuhan
Re: RE: Re: RE: Re: Pictures ROVIS / AN/VIC-3 system (Interc
I got another you interested???
