runing deuce on inside tires
scopionf89
Lacey WA
I Have been thinking alot about taking the out side tires off my m35a2 and just runing on the inside tires. If only to get the light weight for a future move. I would like to know if it is safe to run a duce on just the inside tires or if this idea is realy dum and dangruss. I will be runing it empty only win I have the out side tires off.
1,187
If you insist on removing 4 tires(temporarily), I would take the inner duals off, and run on the outers. You will loose alot of stability, without the outers on. Going in a straight line would be OK, but a sharp turn or an emergency maneuver might set you up for an accident.
Personally, I wouldn't do it, unless it is a temporary situation.
You could flip the rear hubs and single it out, properly.
Heavysteven
11
Hickory Flat Ga
You can do that but you need to flip the hubs. There is several articles about flipping the rear hubs to single them out. Try the search or google. Maybe Clinto will post some links.
scopionf89
Lacey WA
I am trying to lighten my m35a2 up as much as possilble. That way I can add the weight of removed items to my loaded weight. I am going to be driving my m35a2 frome one side of the country to the other pulling my daily driver.
How do I go about runing on just the out side tires? Are duce rims not interchange able?
yetti96
Fort Myers, FL
Still confused. If you remove 4 tires and cross the country, are you still going to take them to put them back on when you get to your destination. If you are towing some weight behind you you will want the weight on the towing vehicle, not the towed one.
Carl_in_NH
Wilton NH
If I understand correctly, you're planning on removing 4 tires from the rear axels so you can load the truck to the 10,000 pound maximum weight for on-road operation - plus the weight of the four tires and wheels you removed (or roughly 800 pounds) as additional payload.
Let's think about that; half the normal amount of tires, and more than the maximum amount of rated on road weight (regardless of their position on the hubs).
I assume we're talking about normal 9.00 x 20 tires here - not super singles that would remain in the back.
My answer would be 'no', that would not be a wise idea.
Tow4
669
Orlando, FL
Tires are un-sprung weight. You save nothing removing them (except maybe a little fuel milage) and lose load carrying capacity. If the tires are going with you, leave them on the axles.
tm america
25
merrillville in
Ok if you gonna be running with a heavy load don't do it. Singled 9.00s don't handle much weight especially for a long road trip.You will have blow outs..I ran mine on just the inners to see what kind of a difference running singles vs. duals as far as accelleration and braking ..huge difference. But i wouldn't do it loaded .Flip the hubs get super singles that can handle the weight..
