Rust sequence on CUCV
Mark3395
Geneseo Illinois
Has anybody ever sequenced the rust pattern on a CUCV as an indicator of age/maintenance. By that I mean a list of where rust breaks our first, then next, and so on. Where are the first places to inspect for rust?
Thanks for any info.
GM72K10
68
Bucks County, Pa.
Cab corners, rockers, cab supports, inner front fenders, fender lips, bed rail supports, anyplace water can get stuck and not drain. Also w/s channels, floors, door bottoms.
steelsoldiers
4,089
Charleston, WV
In 1009's the most common spots are the rockers, the inner fenders under the battery trays, the inner fenders where the reinforcing panel is used to bolt them to the cab, the tailgate, and the floor pans around the support channels and the gun rack. Also look at the seam right in front of the rear seat where the rear pan bolts to the body cross-member.
CARC is great about letting rust stay concealed until it gets poked and a big chunk falls out. Fiberglass and Bondo rust repairs also allow water to sit on the metal and greatly accelerate rusting. Be especially wary of CUCV's from the salt-belt.
Here are some pics from my 1009 restoration project:
2deuce
182
portland, oregon
rust
I'm sure it depends where the truck has been, but out west here, they can be rust free everywhere but under the floor mats. If you find one that has been rustproofed there it can help but those mats will hold moisture until they fall through floor to the road.
Greg
papercu
33
Baxley, Ga.
rust
Check TB 43-0213, it has a complete section just for the CUCV. I didn't see it in the "Resources" section, if not there you can go to the LOGSA site and download from there. Wayne
Michael
39
Fulton, MS
RE: rust
Down here in the south, the only rust I have seen has been under the floor mats. There was a MWO to remove the mats, but a lot of trucks coming out still have them.
