Safe driveshaft length??
Titanium Soldier
Mojave California
Hello all, I am working on a bobber project , but i am doing it a little bit different than the norm. i am installing my axle a bit further back than the usual bobber which (please correct me if i am wrong) usually requires a 5-6" longer driveshaft. I need at about 12 inches further. I measure 63" from flange to flange. So i took it today to the shop (adams metalizing and grinding in lancaster CA) and the driveshaft guy told me it is too long and probably will twist. I know that there are all sorts of diferent things that can make it or break it, diameter wall thickness length and material, But i have seen some pretty long a$$ driveshafts and 63" doesnt sound to bad to me! BUT..... i am not a pro, that being said, has anyone else here lengthened one to that length and what were the results?? and do any of you fellas also think that its to long?? Please give me ur advice or critisism!!
-Tom :beer:
topo
226
farmington NM
can you mount a carrier bearing . you may be able to make the first shaft the right length so that you could reuse your old drive line or get it cut down .talk to your drive line shop you don't want any problems .
Titanium Soldier
Mojave California
I had thought of that, but i would really like to stay away from it if possible. I had planned on just installing safety straps around it, incase it lets go. hopefully they wouldnt need to be used!!!! besides we are fortunate enought to have front wheel drive to get us home!!
jtron79
Eugene, Or
I would say talk to a truck drive line shop. No disrespect but those guys probly only deal with little 4x4 drivelines. Our dumptrucks at work are atleast 70"+ and it's just my 2cents but try to steer clear of a carrier bearing, they wear out quickly and are kind of a pain to deal with.
Titanium Soldier
Mojave California
I think i will stop at one tomorrow after work. Do those dumptruck driveshafts have a carrier??? Like i said before, i really dont think i NEED one but again i am a jet mechanic lol we dont have driveshafts
Awesome Possum
Central Texas
I did my bob about the same length as yours. I just gave them the measurements the way they said to, and they lenthened it by about 13". Only 65-70 miles so far, but so far, so good. I had Inland Truck Parts Company do it, and it cost $191.00.
HanksDeuce
238
Prairieville, LA
My local truck shop, Margot Inc., said that DOT will not allow a driveshaft longer than 68 inches without a carrier bearing. My bobber shafts are nowhere near that. Good luck!
hndrsonj
Senior Chief/Moderator
361
Cheyenne, WY
Good link Dave. Looks like as long as the right size tubing is used will be OK. (pg 18 )
HanksDeuce
238
Prairieville, LA
Based on that PDF with a maximum engine rpm of 2875 and a 5th gear ratio of 0.79 that would be: 2875 / 0.79 = 3639 rpm (max driveshaft rpm).
The chart indicates a max length of 45 inches for a 2.5 inch, 0.083 wall tube.
The chart indicates a max length of 64 inches for a 3 inch, 0.083 wall tube.
I don't have my deuce at my house. What size is the deuce rear driveshaft?
