Heavysteven
- 11
- 0
- Hickory Flat Ga
So after finding oil in the wheel well I dicided it was time to investigate. After all I had just replaced all the seal and boots in my front axle in the spring. I went through everything cleaned greased and inspected. So I thought it might have been the wheel cylinder. Tried to just remove the brake drum nope its froze to the hub. I was wrong the inner axle seal is leaking again and the boot ripped. Frustrating
Questions - Where does the inner boot clamp bolt go? On top do i need to cut the excess threads?
Any one ever had an axle checked for scoring. If scored can it be fixed or should i replace?
I think to fix the problem for now i am going to low the oil level in the axle to 3/4" from the fill hole and put some stop leak in.
FYI: I am not happy with the quality of the "new star silicone boots". Going to try and find a OEM zipper replacment.
Oh yeah and to add to it my brake pedal spring broke off. Well, at least i can tear a hub down and back in 30 minutes flat.
