Shrader valve on fuel filter
ericp351
106
erie Pa
Hi all,
My 5 ton a2 has a screw-in shrader valve on top of the first remote fuel filter in place of a vent or petcock. How or when should I use it, or should I put in a plug or cock? Also, is $30 a fair price for #lff 1201 fuel filter? I believe I am due for the 3,000 mile replacement. Thanks!
simp5782
Feo, Fuerte y Formal
9,492
Mason, TN
Yes it is a fair price but make sure it has the gasket and the oring for the bolt.
Your fuel filter should only need to replaced due to contamination or extended service interval. A service interval on a filter should be 15,000 to 20,000mi. Clean your tank and make sure it is in good shape and replace your filter. You should be fine for years as long as you maintain your system.
Replace the valve with a pipe plug.
Sent from my SM-G860P using Tapatalk
simp5782
9,492
Mason, TN
On another note when replacing your filter. Make sure to idle the engine for 30 mins or more to make sure its warm. Refill your filter canister and install it. Do not let that engine get cold while you are replacing it. It can make for a pain to bleed the air out. Changing the fender mounted fuel filter should only take 5 mins if that. Also wait for a sunny day. Not a cold windy one.
simp5782
9,492
Mason, TN
Clean your tank first. Then run it a few hours and change your filter.
simp5782
9,492
Mason, TN
You can push it to release air if there is any built up from using the primer pump or a forced pump from the tank. Someone just tried something different im sure.
Csm Davis
402
Hattiesburg, Mississippi
Nope the military swapped to the bolt with a bleeder valve on it but why some dumb engineer decided that a Schrader valve was appropriate is beyond imagination. If you leave the Schrader valve make sure you keep a metal cap with a seal in the cap on snuggly, to prevent air from being sucked in as the Schrader valve is only meant to keep pressure in not vacuum.
Sent from my SM-G930V using Tapatalk
