Simplified Injection Pump Plumbing --- Why Not???
SasquatchSanta
27
Northern Minnesota
In a previous post I mentioned a sticker on one of the fuel filter canisters on my new LDS engine stating that the fuel density compensator had been by-passed.
The sticker was obviously in error because upon close inspection I found the FDC to be configured the same as in Fig. 1 below.
I don't want to by-pass the fuel density compensator but I would like to simplify the plumbing by eliminate the two fuel line loops.
"Evidently" the reason for the two fuel line loops, one on the back and one on the block side of the pump are to allow a convenient means of bypassing the FDC.
If this is the case why can't the two fuel line loops be eliminated by removing the lines and plugging the holes? See the attached picture of the back of my pump with the rear loop removed and the hole plugged.
Am I missing something here??? Will removing the loops effect the operation of the pump?
To my way of thinking, if the fuel line loops aren't needed, eliminating them would eliminate a possible source for future leaks.
KaiserM109
SE Aurora, CO
I read up on doing what you are about to do and asked the same question. The answer I got was that the loops are there simply to get the job done with no new parts. If you want to plug them, do it. That's the way I'm going to solve the same problem on my deuce.
FreightTrain
Banned
2,730
13
Gadsden,Al
yep,Yours is Bypassed.Those loops are only in the picture cause the way the TM does it,No new parts are needed.You just move stuff around and reuse all the existing parts but keeps the ports sealed.
Bill W
47
Brooks,Ga
As mentioned in your warning sticker ( I have one on my deuce also ), the reason for not changing out any of the hoses was so incase of fuel emergency the military could hook it back up again being it was only disconected so to prevent oil dellution (sp)
bottleworks
Central NC
That's what I did. I just used some brass plugs. The multi in multifuel still works great. The last time I drove it, it was running on 90% ATF/hydraulic fluid and 10% biodiesel.
SasquatchSanta
27
Northern Minnesota
Thanks for the insight.
I couldn't see any logical mechanical reason how plugging the ports to eliminate the loops could effect the mechanical workings of the pump.
BFR
Rocket Surgeon
2,330
42
North Georgia
I just deleted the smaller loop(the one between the pump and the block) to make installing the fuel supply line easier.
m-35tom
226
eldersburg maryland
ernie, yours is bypassed. so it is not really a multifuel anymore, just a diesel. it will still burn other oils but will not try to change the fuel rate on it's own to control power output.
cranetruck
Meadows of Dan, Virginia
Re: RE: Simplified Injection Pump Plumbing --- Why Not???
The FDC (fuel viscosity compensator, actually) has absolutely nothing to do with the engine being a multifuel or not, it's the combustion cycle that makes it what it is. This has been kicked over so many times in the past, so I'll stop here.
