kastein
- 26
- 18
- Southbridge MA
Just got my M54A2 (LDS465, etc) home after a drawn out blown head gasket saga and it looks like I have some oiling issues:
* the oil filter housings are definitely leaking oil badly. It took me 5 gallons of oil to make it from Mont Vernon NH to Southbridge MA, and I had to keep a very close eye on my oil pressure. The worst leak appears to be from the gasket around the banjo bolt head on the rear oil filter.
* oil pressure is about 30PSI operating, 45-55PSI cold. I'd like to see it higher, but I'm not sure what the spec is and I couldn't find it with a search... the -20 only said it should read 10-30 idling @ op temp, which it does (about 15-20.)
The leaks are probably because I had to reuse the old filter housing and bolt gaskets, as the new filters I bought from TNJMurray (Baldwin filters, I forget what part numbers - the elements fit fine) came with gaskets that just plain didn't fit and I had to get it home. Anyone know where I can get gaskets that *do* fit? If I can't find em, I'm going to order a new set of filters from Erik's and hope they fit, and if those don't fit either, I'm going to go with spin-on filters probably.
The oil pressure... I'm not sure. I really would like it to be higher, but I'm not used to the LDS465 yet, I'm used to 4.0L AMC/Jeep motors that idle at about 20 and run 40-50 at operating speed.
Tried to check the tech manual section for the other TMs I could maybe find this data in (I only downloaded the -20 and TM9-2320-209-34-2-1 back when the old forum was still accessible
) but for some reason it is sending me to the main forum menu instead of the tech manual section.
