Some things I've learned from my first time winching
jrou111
Birmingham, AL
1. Even if you read and memorize the TM, you still have a high chance that you'll get hurt.
2. Steel cable is heavy and very greasy. The grease is there to hide the metal slivers.
3. If pulling a tree over, make sure to measure the height of the tree and that the cable is LONGER than that amount by more than 10ft.
4. 'Low' on the PTO lever is still pretty darn fast. "High" is a good way for you to drag your deuce through gravel with the brakes locked up.
5. It's nearly impossible to get your cable spooled back on the drum NEATLY when operating your winch by yourself.
6. Pulling over a 18" dia. pine tree and watching it topple down will make you giggle like a school boy.
7. Although very very dangerous, winching is fun! :-D
hole
Alta Loma , Ca.
Now you've done it Kenny, I'm gonna HAVE to get a winch for the Deuce now that I see the size of tree I could pull down:-D
brhwilk
Enterprise, AL
Too funny!
Your points of winching are too funny!
I am searching for my first Duce and would love to hear any advice you can offer on what to look for, and what to do when I do buy one regarding getting it home.
Thanks!
Brian
zb39
PA
When your putting the line back on a winch, you need some tension to get it nice. Put truck at bottom of hill and winch it up in N cable will look good. Of course without a level wind you might need 2 people..:-D
jrou111
Birmingham, AL
I dragged a stump to add tension. Making sure the cable stays where you put it at the start, and after you take tension off of it are the hard parts. I'll probably be using it again soon, and once I get a 'soldier B' over to the house I can get it on the drum properly. :-D
