South Wind heater
Steel Soldiers is supported by:
TAKPAK
Hillsboro, OR
Question of the day; has anyone who has an M-43 ever fired up the gas fired heater in the patient compartment? I'm looking to use mine, if it's feasible. Everything looks to be in good shape, unit doesn't seem to have been used much, still "new" looking. However, don't want a possible "bomb" right behind me, inside the vehicle, if there are issues. Both fans (circulation and burner) work fine. Everything else seems to check out. Just haven't hooked the gas line up to it yet. I did ask the question over on the G-741 site, lots of lookers but no comments or replies. Anyone????
gimpyrobb
dumpsterlandingfromorbit!
183
Cincy Ohio
Some of the guys on the m715zone have used theirs, might do some searching over there.
snowtrac nome
20
western alaska
I played around with one that was a 12 volt model, it was missing a fan motor, I tried to make a civilian motor work. It popped and jumped quite a bit but never became a bomb the combustion chambers seem pretty robust, when they are new,an old one with corrosion may not be the same. if the combustion chamber is cracked you stand a chance of co poisioning . if you want a fuel burning heater take a look at planair heaters, they are Russian wabesto knock offs. The products are good, reliable, and safe they burn about quart of diesel over an 8 hour period of time running continuously.
