Sparta Wisconsin ,Mike
phantomjeep
NW Lower Michigan
Sparta -Mike thanks for the help in checking my container-engine and fitting it on my trailer. What a great GL employee Mike runs a first rate yard. My appointment was right on and my lot was waiting on the pad, ready to load. Mike took the time to lift open the container to make sure I had the engine I bid on. Thanks again for the help
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
Mike is definitely one of a kind!!!!!!!!
If there is anything I can afford :oops: at Sparta in the future, I'll definitely be going back.
CharlyArmy
Roland, Iowa
Mike is the MAN
Good natured, always has a smile and easy to work with. Goes out of his way to make the load out easy and quick.
I picked up my ammo cans and commo wire on Friday, Nov 6th and it was by far the easiest loadout I have had yet.
Dealing with Mike at Sparta is worth the 5 hour drive.
BTW, if you are looking for a good place to eat in Sparta, I recommend a little cafe called the Coach House, the hot beef sandwich is awesome.
cornrichard
Galesburg, IL
Mike and Srg. Birkinholtz at camp Dodge in Iowa are the only reason I still do business with GL. The process to get your stuff sucks. Then you get to go look at all the toys and deal with good people on your recovery. A big thank you to those guys.
phantomjeep
NW Lower Michigan
Another great load out at Sparta Wi. with Mike. I arived a day early and late in the day and Mike said no problem. My lot was on the loader ready to set on the trailer and the second lot there to put in the bed of the truck. Strap it down and out the gate for home . less then an hour on base. where else can you get service like this.
Thanks again Mike for all the help in loading and being so carefull with the loading.
