Speedo angle drive-busted
Privatewrench
19
Kentucky
So I'm enjoying a nice drive to my buddies house yesterday and my speedometer drops to zero even though I'm cruzing at 50. After some checking i found that the back side of the angle drive must have had a screw on cap. As the pics show, cap is gone and all the gearing poured out.:cry: I've been checking the usual places to buy a replacement, or maybe just the innerds, with no luck.
Anyone out there have a recommendation on finding a replacement.
Thanks for any advice!
Flyingvan911
158
Kansas City, MO
I had something similar happen. Speedo showed zero. The end had backed out part way. I cleaned and lubed everything and put it back in. I now check that frequently. Even in between grease jobs.
Privatewrench
19
Kentucky
I had something similar happen. Speedo showed zero. The end had backed out part way. I cleaned and lined everything and put it back in. I now check that frequently. Even in between grease jobs.
Yup...I added it to my maintenance log for now on too...at least once I find the parts.
Flyingvan911
158
Kansas City, MO
It’s also a good time to check the seal that keeps the transfer case lube out of the speedo adapter. My seal went out and started slinging lube oil everywhere.
Privatewrench
19
Kentucky
A big shout out to Tracer for sourcing me a replacement angle drive. Memphis Equipment has many in stock, and I have one on the way!:naner:
I guess I'll work on installing my backup lights while I wait on the speedo part. I'll be cruising again by the end of the week.:driver:
