Spindle bushings replaced.
davidb56
1,238
Bonners Ferry Idaho
depends on the size and material of the bushing. .001-.002 is usually fine for a Oil-lite bushing. The Machinest should know that as there is a industry standard chart for common bushings.But I dont know what type of bushing you got. Im assuming you are talking about the bushing ID After its installed in the spindle.
ldmack3
1,740
N. Central Idaho
Correct. NOS busing being installed for new axle so will likely need to be reamed to fit the journal. Don't know what an oil-lite bushing is but these are grooved to pickup the knuckle grease...I think.
davidb56
1,238
Bonners Ferry Idaho
If I were doing it, I'd just slide it over the axle to make sure it was the correct one and slap it in, then go. But I only drive about 10 miles a trip max, so it will last me forever.
