squealing belt?
m242brushmaster1
Bellefonte, PA
This is probably a dumb question, but here it goes. When I flip on the acc switch in the deuce, I here a squealing noise and then it stops when I turn the acc off. Now could that be the belt or a bearing going bad in the alternator?
phil2968
17
Lakeland, Florida
Mine has started to squeal a little after start up. Going to install new belts and keep these in the box for spares. The load on the altenator is greatest just after start up, belts can squeal then. Turning off the master switch kills the alternator and the squeal. Hope this helps.
m242brushmaster1
Bellefonte, PA
Yes, when the deuce is first started up, it will squeal but I let it idle for 5 minuets and the squealing stops. When the master switch (the switch us around here call the acc) is on it squeals and once turned off the noise stops.
steelandcanvas
85
Southwestern Idaho
Check the Alternator, with the belt off, make sure the pulley rotates freely. A friend emailed me about this same problem last night, his alternator had froze up.
Jimma
Hartwell, GA
I had the exact same problem. Squeeling on start up that sometimes stopped after the truck warmed up. It only did it with the accessory / power switch turned on or in the up position. It is easily fixed. Its a loose belt on the generator, might not look loose with the naked eye but you will find it is. All you have to do is loosen the bolts on the generator / alternator push it as far to towards the passenger fender as it will comfortably go then tighen the bolts. I pushed mine with a 2x4 and held it while a buddy tightened the bolts. Its a quick fix and the problem never has re occured. That was over a year ago on my 68 Jeep Kaiser M35A2.
phil2968
17
Lakeland, Florida
Just make sure the bottom bolts are loose before you pull with that 2x4! You can break the ears off the alt. Ask Doghead how his worked out for him.
Jimma
Hartwell, GA
Yeah, we loosened all the bolts, pushed but not too hard, then tightened it all up. No problems, no embarassing squeeling anymore.
Barneyszoo
12
Riverside, CA>
If you rub a bar of soap on the sides of the belt it should stop squeeling, that will be the belt you should replace. Belts get glazed and lose traction on the pulleys and when the acc is under load the belt will slip and make noise.
1,168
Accessory switch, yes. A2 and A3. It does help when we use proper/common terminology. TMs are good for that.
