Starter not turning!!
kcbbqguru
kansas city
I did doghead modification and truck didn't start. Checked the wires and found a loose one, tighted it up and starter turned over. truck would not start. starter turned over 3-4 times then stopped turning over. it is a newer gear reduction model about 2 years old. starter BAD?
FMJ
37
Las Cruces, NM
Gear reduction starter? If your system is 24 volts you may have cooked that starter, unless, somehow it is a 24volt gear reduction starter?
Sorry, new information has come to my attention regarding the 24v gear reduction starter, disregard my prior transmission.
Warthog
227
OKC, OK
Gear reduction starter come in 12 and 24v. I have a half dozen of the 24v out in the shop.
the purple/white wire will have 12v when the key is in the start position. The black wire is ground.
the red wire should be 24v at all times. The purple wire should have 24v ONLY when the relay is engaged.
FMJ
37
Las Cruces, NM
Could I get a part number for a 24 volt variant?
kcbbqguru
kansas city
It's a 24 volt gear reduction, sorry don't know the part number
Warthog
227
OKC, OK
Heres the info:
24v 28MT Gear Reduction starter
GM - 10479611
NSN 2920-01-353-7036
NAPA - WIL 91014417
You will also need the dealer only support bracket for the GR starter
GM - 23502557
Warthog
227
OKC, OK
kcbbqguru, you may have a bad relay. I have seen new ones that are bad from the factory.
I'm guessing you have a multimeter and know how to use it.
You will need to check the voltages at the relay and at the starter.
How long have you had the gear reduction and where did it come from. There have been many reports of some import starters that are not worth the more that the scrap value.
