Steel Soldiers MV of the month 2025 - June VOTE HERE!
  • This poll will close: .
5,104
1. biscuitwhistler37
2. glcaines
3. SCM35A2
4. msgjd
USAFSS-ColdWarrior
Chaplain
6,183
With FOUR worthy candidates, we again have tough choices to make here.
Gonna need some convincing campaigning before the twitchin' votin' finger is allowed to spasm on just one selection button.
Give us your best pitches. Convince your voters......
May the best MV win!!!
CHARGE!!!!!
SCM35A2
3,283
Florence, SC
Here is my 1964 M35 A1/A2 w/winch truck, was converted over to an M2 model/multi-fuel in the late 80’s. I have owned the truck now for 5 years. The truck was in decent condition when I got her, so I started with the mechanical stuff to get her road ready. I pulled off all the wheels, removed 40 plus years of paint & repainted them. While doing that all of the brake components were replaced-(wheel cylinders, bearings, seals/gaskets, all hoses, master cylinder, rebuilt the air pack, brake shoes-all) & added a brake fluid reservoir kit to the inside of the truck. Other mechanic parts replaced was the entire exhaust system from the turbo back, speedometer/tachometer cables, gauge grounds, all filters-(oil/fuel/air), front axle boots, belts & removed the old axle vents & replaced them with ¼ fittings that allowed me to run the air lines up & away from them-(see pic). I also swapped out the old battery box for an updated/bigger plastic version so I could run two group 31 batteries along with all new cables & grounds. One last thing was to have the starter rebuilt & replaced the old solenoid. So now she starts, runs & stops!
Next I swapped out off the reflectors, headlights, air breather stack, mudflap guards/mudflaps-(semi-trailer) top winch plate & added a cover to it. Tailgate needed some new step handles & rear bushings so those were replaced as well too. Scored a vintage military issue Pioneer tool kit, so installed that along with all new hold down straps.
On the inside I’ve only done a few things such as new upper/lower passenger seat cushions, new pedal covers, shifter boot, new wiper motors & blades, starter push button, added a battery kill switch & new fire extinguisher.
The truck has the LDT-465-1D multi-fuel engine with the whistler c turbo & besides me completely taking it apart to clean/detail-paint everything its basically stock. The truck came with the non-air assisted transfer case, but however that has been since swapped out to the air powered model.
I just recently bought an M105 trailer to pull behind her & also have a tow bar that I plan to mount in the bed as well. As soon as I swap out the hard top on her for the better shape one I’m going to have a few rust spots fixed & repaint it.
I'm going to post pics of what I started with & how she currently looks...
