Steering arm removal
sebaeb
sidney/oh
I know this isn't a CUCV, but i don't have anywhere else to post and ask....chevy dana 44 front axle...it had a ORD cross over steering kit on it...im in the process of dropping it back down to factory height and cant seem to figure out how to remove the ORD steering arms from the steering knuckles
Thanks in advance
BigRix
Tucson, AZ
I'm not sure about the particular arms you are using but if they use cone washers you need to hit the side of the arm to force the washers up. Once they are loose the arm should come right off. Do NOT hit the studs, just the arm.
