NormB
- 77
- 48
- Cloverly,MD
So the steering column on my Humvee M998 1992 (build date 12/1991) is broken. Thought the bolts needed tightening - place I bought it assured me it would be done before I picked it up but money had changed hands and well, I got screwed - little tab on one side is broken and the hex nuts are frozen in place.
I'd bought a replacement bolt/nut kit and after doing the grounding wire/loom install today thought okay, now to tighten the whole thing down.
First, I'll need to take a nut spitter to the nuts, they're frozen in place - loose.
So, back to the part book (P-1 AND P-2) to figure out what I'll need to replace the column. Even did the usual websearch looking for information, MWOs, etc. No Joy. Then to the classifieds here, did several searches here, as well as at the usual online parts sellers, and eBay.
QUESTION: what is the difference between the two types of kit, 57K3216 and 57K3205?
Wow, not so loud... sorry.
If I'm seeing the photos correctly, it seems the earlier column had slotted holes for the allen-head cap screws, the later model (57K3216) didn't, just had a single hole drilled.
Is this right?
Thanks in advance.
Norm
Is this right?
Thanks in advance.
Norm
