Steering Column Problem (VIDEO)
Barrman
2,025
Giddings, Texas
It seems to me that you have 1 too many clicks of the key before you get to power on. What is your "run" position is actually, the start position as far as the column is concerned.
You need to adjust your ignition switch. Yes, the one on top of the column that you can feel, but not see. Use a 5/16 wrench to loosen the front bolt and a 3/8 to loosen the rear bolt. Slide the switch toward the seat until you feel it click once. Tighten it back down and see what happens.
The dimmer switch will have to be removed to loosen the firewall or rear stud on the switch.
Do you happen to have an accessory position if you try to turn the key backward from what your video shows as locked? I am thinking you won't.
The key positions are acc, locked, unlocked off, unlocked on and start.
zuess253
janesville wi
I agree with the above post which Barrman says when you truck is in the run position the key is one click too far forward. Adjust the ignition switch should solve your problem. If that doesn't work the column will need to be taken apart and fixed. It's too bad your not closer or I would fix it for you.
ilovemyblazer
Manitowoc, Wisconsin
Thanks so much for your help guys! It was exactly what Barrman said. I adjusted the ignition switch and the column works perfectly now! Thanks again. Now I just need to get the engine running right :-o
48cj2a
35
Central, IL
I put one in my CUCV too. If you want intermittent wipers you'll need a different wiper motor and the wiper module that goes between the dash wiring and the column wiper wiring. Found mine on an 87 Custom Deluxe Crew Cab and I also swapped over the better wiper arms with intregal washers, washer tank with the intregal washer pump in the tank.
I have a write up here: The 1947 - Present Chevrolet & GMC Truck Message Board Network - View Single Post - 85 CUCV Build
and here http://67-72chevytrucks.com/vboard/showpost.php?p=4890391&postcount=24
