Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Hello to all !! Need to replace the damaged steering column in my M880
with a stock unit or upgrade to a tilt column. Anyone know what years fit and possible suggestions ??
Thanks...
Bob
Any of the 70's should fit. 81 and newer is different. Tilt columns are different too and generally have the ignition switch under the dash. Don't switch to tilt unless you get all the associated parts.
any column from 76 to 78 will work. Just make sure the electrical connections are correct. If You are good at taking things apart, You can change out the electrical componets.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
