cucv1833
- 4
- 18
- Lake Charles, LA
Still cant figure it out. My 85 M1008 starts up great idles good. but when i take it down the road it completly shuts off after a distance of 1 to 5 miles.
then it turns over a few times and cranks then does the same thing
after searches and my recent post i thought fuel problem
Ive changed all soft lines from the tank to the IP
>the fuel supply pump
>the fuel filter and base
>sending unit in tank is 1 year old tank is clean
I have bled the air out the fuel lines and pressured up the tank with 3-4 psi
the cap is a gasser but vents no problems before
Now i think it is electrical i did wire a radio and amp to the 12v junction block on the firewall same as my buddys M1009 thats when the problem started could i be pulling to much power are burnt something up (fuel cut off solenoid)
Any tips will help Thanks in advance
Find the pink wire under the front of the air cleaner. Strip some insulation off it and attatch a short wire to it that goes to +12volts on the front battery. Electrical tape connections so nothing falls off and shorts out. Go for a drive. If it doesn't die - you have electrical problems. Disconnect the test wire you put in before leaving the truck, it'll kill your battery. Oh, and FYI you will have to remove the wire to shut off the truck. Key won't stop it. Good Luck.
