Stock horn replacement
Steel Soldiers is supported by:
Stevev
Dover nh
Hey guys
I ordered a new louder horn and it only has a blue power wire and the unit grounds when you bolt it in I guess
the current horn has two wires with identical plugs any idea on how I would wire it so I have 24v to the new horn?
52
kingston/ NH
Wire 26a is 24+ power to the horn, wire 25a is the horn button, which grounds the circuit. You need to figure out how to make the horn button ground to activate the horn.
Stevev
Dover nh
I figure it would be easy
so are both wires power?
i tried testing them with my meter individually and got nothing when pressing the horn but old horn works fine
Andyrv6av8r
17
Spartanburg,SC
It seems like you need to insulate the horn from ground when you mount it. Connect 26a to the wire on the horn. Connect 25a to the horn body.
Stevev
Dover nh
This was a cheap horn
only $30 and is 350 db
is there a horn you recommend?
i just wanted a louder one then the mouse squeak I have now...lol
Chief B
10
Milton, FL
This is what I added to mine. For the button I simply added a button for it to the ammo can i mounted on the radio tray.
265
SW Ohio
A relay in the circuit will work also. Wire 26a to one side of the windings as well as one contact. The other side of the windings is connected to 25a. The other contact is wired to the single horn wire. The horn is grounded through its mounting.
The horn button grounds the relay when pressed, sending +24 to the horn.
