- 3,923
- 76
- 48
- Comfort, Texas
I have had my Deuce for 2 years now and always started right up and ran great. The last three times I started it, it starts fine and then stalls after about 15 - 20 seconds. I crank it 2 to 4 times without success and then wait about 15 seconds and it starts up fine. Today I noticed that there is a squeeling sound at the front of the engine and I thought it might be a water pump bearing going bad. I turned off the ignition switch and before I pulled the stop handle, the sound stopped. While it was still running, I turned the ignition switch back on and the sound came back. Turned it off and it went away.
I checked the belts and they look fine and the in-tank fuel pump is making its normal sound. Any suggestions?
I have also started to get random blasts from the horn without pressing the horn button. I will gladly take suggestion on that one while you are at it.
TWM
TWM
