maxim
- 10
- 18
- Manistee National Forest Michigan
Any one have a suggestion for removing a stubborn steering arm. The one that goes from the steering box. I have soaked in Blaster, used the largest blade screwdriver with a wrench on it. I have not hit it with air yet or put heat to it. I know there is a spring inside the arm so I hesitate to use too much heat. Of course the cotter pin has been removed and I have tried tightening or loosening. Maybe give a couple of blasts with the air hammer on the end? The threads are fine and I do not want to bugger up the threads or the slotted plug. There is a bit of play in the arm at the ball joint and it needs to be cleaned and adjusted. I have taken them off before but this one is testing me.
