stuck u joint on a m1008
84cucv1ton
New Jersey
rear axle of a m1008. bent my 4 foot pry bar. thought i would ask before i damage it. would heat it but i need to get my bottle filled up. ideas? thanks
doghead
4 Star General /Moderator
1,188
NY
Use a torch
look out for exploding gease.
84cucv1ton
New Jersey
drive shaft off the pinion yoke. just got the bottles filled doing it soon. bunch of trucks to cut up should be fun. its really hot out
scoutdoors1000
Columbia, SC
Drive it around till the U joint breaks, the axle goes flopping around under your truck and you are barely able to make it to the interstate exit.....that is what I did. No problem getting it out of the yolk.
