Studs and nuts
sermis
17
Temple, TX
I need a source for the studs and nuts for the 5 ton bolt together rims. Without going through the mud and looking at the rims I am not sure how many I need or what size they are. I m thinking there are at least two different sizes. I have both the 10 and 20 bolt rims. Also in need of HEMMT studs and nuts for the rims.
Cdub
New Milford, NJ
For the ten bolt combat five ton rims, there are two different size studs.
5/8" for the A1's and 3/4" for the A2's
C'dub
dma251
17
Arlington, Washington
I searched fruitlessly for some time to find the correct 3/4" stiuds for my hemtt wheels... It's not easy...
I ended up ordering a bag of 32 of them for $4 each.... Yup. $4 each from Oshkosh.
I took an example to both the major fastener companies in the area, and also to a major truck dealer. No dice...
The closest I got was a wheel stud that might have worked if I ground flat sides on the rear flange, but by the time I did that it would have cost me the same as just spending $4 edach for the right ones.
Sorry I don't have any better news. Giood luck.
jwaller
19
Columbia, SC
I know SECO has the correct studs and nuts for all sizes of these wheels. I had to buy a few to repair some of mine. they aren't cheap or even close to cheap but if you want the right stuff they have it. I think they were about $20 each.
dma251
17
Re: RE: Studs and nuts
$20 each!!! :shock: :shock: :shock: aua
Let's see.... If I needed 16 for a hemtt wheel that's $320, plus $15 for the o-ring, and $21 for the valve stem.... That's $356 per wheel...
9 wheels - $3204.... That's for nuts and studs... Not even the wheels... Just nuts and studs.
Someone's getting rich on this, but it's not the us. Get them from Oshkosh. I can get you the part number if you want it.
