$80 must be the minimum bid on Clist....
btw, my new to me, 1990 Dodge tug has a Dana 70, Detroit locker and 7.17:1 ring and pinion. I'm told I can re gear this thing to a 4.10:1. Does anyone have a set of 4.10 gears for this axle that I can buy cheap? I am considering "un bobbing" the tug into a daily driver.
I suppose without an overdrive transmission, my best choice would be to just use a different axle with about 2.70-3.08 gears. Just thinking outloud here.
on your front axle, you will just need to swap out the outer hubs to 8 lug outers, everything else is identical to the 3/4T front axle, the D-44 and Corp. 10 outers are identical, that will save you some $$ there, and the rear Corp. 14 B is a dime a dozen, cheap and stupid strong, downfall is the center chunk is massive !!! and with 32" tall tires, offroad you'll notice it's boat anchor characteristics, it's doable and the draw back to it is gear limitations, they only make gear sets up to 5.38's where as the D70 has better gearing options, but they are spendy. With 32" tires I wouldn't worry about upgrading from the 1/2T axles. Unless you plan on beating it up severely. My buddy rock crawls his jeep with a d-44 and 39.5" tires with a decent 350 and 3.8:1 t case (tons of torque from gearing) and has yet to snap an axleI have been wanting to change out my axles for a while now and I would appreciate some input regarding my choices. Mainly I want the better gearing of a 4:10 or 3:73 and I would like to have the 8-lug 16" wheels so that they match my Suburban and my I've been wanting an M101A2 trailer for a while and I'd like to be able to swap tires between the three as needed.
I've got a local lead on two different rear axles that I'm thinking about swapping into the rear my M1009. One is a Corporate 14 out of a mid 80's farm truck and one is a Dana 70 that a guy already modified to fit into a 1978 Blazer. The one guy with the Corporate 14 only wants $150 and it's complete with brakes and even has some tires with steel rims on it. So which do you guys think is the better choice? Right now I'm waiting for the guy to call me back on the Dana 70 so he may throw out a price that is way out of the ballpark. I'll update the thread when he gets back to me. But strictly from a mechanical stand point which do you think would be better?
Now on the front I was thinking of either doing a Dana 44 or I read on another thread on here that I can just convert my front 10 bolt to an 8-lug. Keep in mind that I'm not thrashing this truck or going out rock crawling. I just want a different gear ratio and the ability to swap tires around. I run 32" tires on the M1009 now and that's what I'm sticking with. So I really think that that factory front would do. The only reason I'm wanting a different rear axle is that that ones I've found for sale are usually about as expensive as the parts to re-gear my current axle. I'm also not afraid to spend some extra dough though on the front so I'm open to other suggestions there beyond just converting it to 8-lug and then re-gearing it to match the rear axle.
So what do you guys think?
