T/C Oil Pump Spring
Aussiecowboy
Echuca VIC, Australia
Hi all,
I investigated the worn out input bearing on my transfer case today, the bearing is damaged due to lack of lubrication. I pulled the t/c oil pump and found it non functional due to a damaged spring. Can someone tell me the correct free length of the spring so I can source another one.
Cheers
Wildchild467
58
Milford / Michigan
If you look in the parts manual and get the NSN, that might help. You can then search for another spring online and see if somebody has one.
