Take apart Deuce Light switch?
Flatlander
Lubbock, Texas
My Deuce light selector switch isn't working too well...I took the screw out of the back, but don't want to break anything...anyone know how to get the switch apart without destroying anything? I'll probably buy another one anyway, but I love to take things apart and see how they work....
Thanks!
doghead
4 Star General /Moderator
1,192
NY
After removing the screw, you need to press the back into the housing just a little bit, to remove the retaining ring.
vtach
North Dallas, TX
Some of the older types were tack welded, but you would be able to tell by looking at it. I used a dremel to cut the welds on one of mine. Alot of times the contacts in side them just need a good cleaning.
The newer ones are as Doghead described. It takes some good force to split them. The switches are quite neat on the inside. I used an ohm meter to map out the contacts on my M37's as I had no plug to connect to the back of it. I then made a plug so my lights would work.
chrismanby
Copenhagen
HI
See in the M151 section, there is a photo of one that came appart all by itself !!
There are quite a few different types of closures, some with locking ring, some have only the "0" ring, and some have been sealed with silicone also.
I am working on these light switches also, there seems to be different types of circuit breakers also.
Chris.
Flatlander
Lubbock, Texas
Okay, finally got it apart...used some adjustable pliers to pull it apart. Seems the plastic cam was forced inside (probably from not using the unlock lever)
Anyone know if there are replacement plastic parts and contacts available? The switch seems to be in good shape except for one little part...
Thanks for everybody's help!
chrismanby
Copenhagen
Hi
The one I had explode looked like this when the smoke cleared and I got the last parts out.
Seems there had been too much juice on the lights (H4 inserts) Not that the amps were too much, but the breaking current may have been too much for the contacts and therefore led to to a "melt down" on the contct surfaces and thereafter melted insulation on the leads.
The contact surfaces on the breaker swith look OK.
Chris.
