Tapping into the fuel line....
docpadds
Ashville, OH
My M46A2C came with a multifuel heater in the box which was never actually hooked up. I decided to remove that 100lb monster and have just go a UH48 heater for the box.
The wiring for the 24v and the thermostat are already in place which is great, as is the exhaust on the front of the box.
All that said.... there is no fuel line and i need to get a feed from the tank up to it. Is there any suggested, or actually intended, junction point i should be linking into? I was going to use modern fuel line, any thoughts on how best to hook into the trucks copper lines?
snowtrac nome
140
western alaska
Those heaters had an extra stand pipe we had to add to the tanks, with a small facit fuel pump mounted in close proximity to the fuel tank. the reasoning being that the stand pipe wouldn't dip deeper than the fuel pump and draw the tank empty causing the engine to die also the turban lift pump in the tank was most likely a higher pressure than the little 10530 heater needed.
docpadds
Ashville, OH
This newer model has the pump built in, not like the old monster its replacing. It has zero information on hookup because now they use them in all manner of things.
The stand pipe makes sense, not sure if i could do something similar, my tank is tough to access.
snowtrac nome
140
western alaska
You could use a 90 degree drill to bore a hole in the tank and use a bulkhead fitting to seal the hole, with a stand pipe on one end and a pipe thread on the other. The filler necks on those are large enough to stick an arm into, or you could use a fabbed up stand pipe, gasket, and some self tapping screws good luck
