- 10,350
- 74
- 48
- Meadows of Dan, Virginia
Got it. Yes, it was mentioned before, but it seems I learn more from repetition.I think it's been discussed before, the T930 engine comes with 2 (identical) starter engines, mounted on the left and right side of the crank case. There is a key switch on the dashboard to select starter 1, 2, or 1+2. In extreme cold the engine gets harder to crank, so you use both. Other than that its always nice to have a spare starter in case one fails.
Thanks!
What is the KW rating (hp) of each starter motor?
