aaron1009
- 0
- 0
- Birmingham, AL
Recently while cruising, I lost almost all drive power. Truck eventually stopped pulling at all. Coasted to a parking lot and put it in park. Back into drive and it caught, pulled, then stalled. From then on, when cranked and in park, the truck sounded like it had dropped a cylinder. Put into any drive gear (including reverse) would cause the truck to stall abruptly. Cranked in neutral, the truck ran normally.
Sounds like it's time to drop the tranny. Alright, here's my question. Is the TH400 in the 1009's at all different from any other TH400 found in Chevys from the 60s-80s? I imagine it has a shorter tailshaft, but that could be swapped from my old TH to a used one I bought, correct? Or is the TH in our 09s different to the point I should just drop it off at the shop and have a professional rebuild the one I have?
TLDR: Would a TH400 I bought from Joe Junkyard bolt up with no problems?
