the deuce is home
croftonaviation
crofton ky
Went down to Ft. Campbell and brought home a deuce today. I am pretty sure I did not get the truck that was described. The pictures match but that is all. The truck I got has 62000 miles showing where as the description said 44000 and the hours were off by about 1000. Tonight when I get home I need to see If it even was the right S/N and manufacturer. On the bright side it has a heater, a new cab canvas top and a turbo (dead batteries so I don't know about what kind yet). Overall It appears to be a decent truck and I'm not taking any bets as to actual mileage and hours. More info and pics as they become avaliable and yes this was a truck on the hold list.
croftonaviation
crofton ky
Yes, this truck was on the hold list. The site manager said GL told them to release any trucks regardless of the hold status with a paid in full invoice. I asked what was the hold over and he could offer no answers. My truck did not have any stickers on the dash in reference to being tested for radiation. I will know more about the year of the truck and the instruments when I get home tonight.
croftonaviation
crofton ky
And running
had time to replace the batteries and see what I had this weekend. I think I got a pretty good starter deuce. with the batteries changed the truck started first try in under a second, ran good and built good oil pressure. I drove it around on the farm and the drive train seems to be in good shape. The truck was rated as an H7 on GL here are the pro's and cons
Cons
Missing glove box cover
pipe doing from turbo to j pipe has bottom worn out of it
paint is faded
brake lights don't work
spedo bounces around
Horn inop
No spare
Pros
Truck has a "D" turbo
2 water type heaters
new canvas on cab
air shift front end
it runs and drives
I think this will make me a good deuce. She needs a little love but I don't think anything that is wrong with her is too bad. More pics coming soon, and I will be hunting the classified section soon to buy some parts
BugEyeBear
Eastern Georgia
Sounds like a nice truck!
Glove Box Cover should be easy to find/replace.
Brake lights issue:
I'd guess that either your military light switch is in the wrong position, or switch could be malfunctioning...
OR your pressure switch is bad...
OR you have blown bulbs...
OR maybe just a loose wire or connection.
Speedo Bounce:
Probably either a cable that needs lube...
OR could be a bad speedo gear.
Horn:
Bad steering wheel button?
Bad switch at horn?
Loose wire?
Bad air line?
(My horn is currently disconnected as it was getting stuck ON!)
Spare is easy & cheap to replace!
ENJOY!! :-D
GoHot229
I had my Deuce for a while and the only lights that worked were the two running lights on the rear, hence, fake brake lights for driving around town (manualy turn the switch on) so that suked, but I had all new bulbs given to me with the truck, so I replaced them all and bingo everything worked. I wonder how long the military used it without lights, as they went one by one till nothing worked? I think theres a J pipe in classifieds here still? Yea, the spare's nut'in. All in all sounds like you did good.....
