The M931 couples to which trailers?
schoobie1
Calgary, AB
I won an m931a1 with the idea of hauling medium size construction equipment such as dozers, loader backhoes and tractors as well as other materials not exceeding 25 tons.
I would like to get a semi that fits right in with my m931 without any mods.
Is the m870 an option?
if not what can be coupled to this?
NDT
7,142
Camp Wood/LC, TX
The M870 is an option, but you will need a behind the cab winch to raise the gooseneck after frontloading. 870's are quite hard to find and are usually somewhat parted out when purchased from GL. Most any civi lowboy will couple to the 931, you might have to crank the legs up some. Don't plan on high speed highway travel with 65,000 lbs in tow.
schoobie1
Calgary, AB
An M172 Trailer would fulfill the role, and doesn't require the winch...
Oh yeah, I googled M172 and that looks like what I am looking for, and it has ramps! That is something I forgot to mention we need too. We have run into situations where we received the equipment but the trailer has no ramps and have to scramble to build a temporary platform or dock to unload the equipment.
Any ideas where to find one M172? I googled GL auctions and not one M172 was sold in the last year, but highest bids range from $1K to $4K from previous years.
NDT
7,142
Camp Wood/LC, TX
M172's are 114" wide. Meaning year-round permit or trip permits every time. The ramps for the M172 should come with a coupon for spinal reconstruction surgery. The 872 is the same height as a normal float. Not useful for equipment drive on loading, must have a dock. Keep your eyes peeled for a 25 ton Hyster or equiv civi lowboy. Same utility as a M172 but standard width.
jdknech
Jeffersonville, Indiana
SOME states do not require farm trailers that are over sized to have permits.. if it is for farm use, its worth checking to see if your state is this way.. Indiana is..
EDIT- just noticed your from canada, I have no clue about what the laws are up there
M931
DENMARK
about the M931 how much it can tow... i believe they mean 55000 lbs .. that must be the load on fifth wheel. they use it to tow trailer there can load 40t [thumbzup]
