Y
Your just showing off now !!! lol I bet you had nightmares about crimping pex pipe after that !Got everything under the counter up to the actual level it will be assembled. Added my hot water return from the shower (missing the check valve), added cutoffs for the sink lines (yeah, that one red handle on the blue line triggers my OCD). LOL
Went ahead and cramped the assembly together into main sections (I can now pull it out with it falling into a million bits). Just need to snip out a 3" section for the last check valve (I'll pick that up next time I go for supplies).
I'm gonna go thru everything and document a few details tomorrow, then label everything and gut the entire hab
Cut the last of the holes for drains, etc, then shift to electrical.
Delete the wires I have ready to pull, delete the last overhead fixture, add the 12/24 run from the OEM battery box to the electrical closet. Two outlets to rewire (were the phone drops, one will be USB charging port and one will be a spare GFI outlet above the sink) and three new drops to land (fridge 120v , microwave 120v, and water heater 120v).
Then it's time to prep for paint !
