Throttle Cable Again [emoji31]
Truckyea
Elyria Ohio
Hi guys, I'm have the same trouble everyone else seems to have with these darn things.
It's impossible to grind the crimp off the Y270 cable without causing slight damage to the cable it's self.
This time i've gone through 2 in a week, my 3rd cable install over all.
Anyone know if there is a Lokar or something anything else than these parts store replacements?
Truckyea
Elyria Ohio
I went ahead and got another #Y270 throttle cable from my local Advanced Auto Parts.
This time I did not bother removing the crimp.
I just simply used some pliers to slide the plastic firewall connection off the cable sleeve till it was out of the way.
I then cut the rubber off with a utility knife about 1 inch or more further away from the original end of the sleeve.
Follow by cutting the inner flexible metal sleeve with wire cutters.
Then I just help the metal sleeve with pliers in one hand and unraveled it with the old wire cutters. Took less than 15 mins total.
When done I just slid the plastic firewall connection back into place.
Truckyea
Elyria Ohio
This is essentially doing the same thing and removing the crimp from the cable, but faster, easier and better.
