Tie down anchors
Nick
Near Daytona Beach, Florida
The front end of my M101 has the tie down anchors, but the back doesnt. Id like to find the same kind for the back, if at all possible, and weld them on.
Can anyone help with where I might be able to find these kind of mounts?
Nick
number9
Lexington, KY
I think those are lift shackles for air lifting / ON-OFF loading the trailer. You could look for some on ebay, seems I've seen them come up there from time to time.
Nick
Been lookin there for some time, have had my trailer for about four years. Was just hopeing someone here would maybe have a scrap frame with em on it or have one extra pair layin around.
Nick
rosco
32
Delta Junction, Alaska
Besides a "parts vehicle", make them. You should be able to come close enough to the original shape, that most folks can't tell the difference. For the loop part, a commercial clevis should be adequate. Otherwise a salvage yard - go shopping.
Lee in Alaska
Nick
Yeah I guess I shoulda mentioned I have four shackles, I just need the anchor to hook the shackles to.
RKBA
Thos are nice, look like they wont stick out too far on the back and be knee bangers.
Whats the difference between front and back shackles?
Nick
RKBA
Northern Nevada
RKBA
Nick
Well, on mine the fronts were 4" with a threaded bolt pin. The rears are 2 3/4 or so and use a cotter or hitch pin to retain the shackle pin.
RKBA
Northern Nevada
Huh, Im gonna put the same size on front and back. Whats the theory behind the different size shackles? Are the mounts the same size front and back?
Nick
To be honest with you, I have no idea why they might be different.
The rear most cross member (where the clevis mounts were) was heavily damaged when I bought the trailer. It appeared that Private Snuffy had tried to pull the trailer over rough terrain with the landing leg deployed. Since I wasn't planning on airlifting the trailer anyway, I just cut it out and left the rear of the frame "open." All that being said, I don't have my rear mounts and didn't take any photos of them before they went to the recycle bin.
I just tested the smaller rear shackles on the front clevis mounts on my frame and they fit like they belong there.
