Time for Fluid Changes on M944-A1
Fastfunco
Mohave valley , Arizona
Can you guys tell me what would be best Oil to put in the differentials. Also- any additives ???
how much will I need to service all 3 Diffs???
Coolant and Oil were like mudd!!
I flushed the radiator 8 times - running the engine to operating temp each time before dumping-- - its happy and clean now-- used old reliable green presstone
I used T-6 Synthetic for the oil-
Dextron/ Mercon for the Allison????
any input would be greatly appreciated--
The Beast is coming along-- I will post some prelim pictures-- we are doing body and paint right now
rangereter
Natural Bridge, ny
About 3-4 gallons per diff/axle...you don't need additives if you use the 80/90 weight gear oil (since there are no clutches). You can't go wrong with Dextron in the transmission...not sure how the Mercon would affect the clutches.
Regards, Bob
