Tires wearing out too fast
Kenneth Cole
44
Wapiti Wyoming
Hi
I got my Humvee about 8 months ago and I knew the rear tires were getting down there and so I got 2 tires off of Ebay that were at about 85% tread. I have only had them on about 3,000 miles and the rear tires are less then 40%.
Has anyone had this problem?
Ken
Sintorion
14
Fla
I think we can all be sure that it wasn't from smoking the tires. :grin:
How are you determining the wear? percentages with tires are grossly over estimated. You need a tread depth gauge and start from there. The Goodyears start with 21/32 of tread. Are you saying that you started with around 18/32 and now have 8/32 3000 miles later? You would have left a trail of rubber to do that. As Papakb asked, what do the tires like?
Kenneth Cole
44
Wapiti Wyoming
Hi
The tires are radials and the wear is mostly on the center. I don't have a tread depth gage but the fronts are about 1/2" deep and the two rear are 5/16" on the right and 3/16" on the left. When I got her the rear left was also the most worn.
Ken
1,187
Are your rear brakes dragging?
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
If the center tread is worn, your running too much pressure. Try using the chalk metod to find the correct tire pressure.
1,187
How much air pressure are you running them at?
diesel dave
north central pa
My tires were wearing out faster than I thought they should. Spent the big bucks ($65) and went to the local Chevy dealer for a 4 point alignment. I could immediately feel the difference. Rolled so much easier. Tire wear has slowed dramatically.
Action
1,561
East Tennessee
Could the exhaust heat have anything to do with faster wear at that tire? My left/rear wears faster too. But mine are even wear with all 4 presssures the same.
Sintorion
14
Fla
This all sounds like speculation. You need a tread depth gauge. Take measurements across the width. At this point any advice here is unfounded because you don't know what it was before and how that relates to where you are now. The only way the centers will wear faster than the shoulders is over inflation and that pronounced wear would only occur in 3000 miles with some serious over inflation coupled with very high speed driving. That obviously isn't possible in a Humvee.
juanprado
3,076
Metairie/La (N'awlins)
Center tread wearing can also be a radial pull and belt separation of an impending tire going. It would look more uneven and the tire would start to ride and feel very harsh.
Awol
590
MA
The MTR's wear like iron, so for them to wear that much something isn't right.
tage
69
LOS ANGELES / CALIFORNIA
old tire + heat. I could see it. All tires off gas, add some heat to help speed it up. They usually throw off chunks of rubber, or the rubber is very gritty/soft.
It's not normal though.
Kenneth Cole
44
Wapiti Wyoming
Hi
Yes I don't have a tread depth gage but I am using a machinist ruler and I know that the rear tires were about 90% when I put them on and that was only about 3000 miles ago. I have 30 PSI in the tires. Some have talked about wheel alignment. I am new to the Humvee and is it because of the independent suspension the you can align the rear tires? Is this something that a regular tire shop can do?
Ken
cwajciec
Richmond VA
I aligned mine with a string and a measuring tape per the TMs. They were way off in the rear. IF you have toed in or out rears then they would wear very quickly. Spec is slightly toed out in the rear and toed in in the front. Both can be adjusted with a pipe wrench on the tie rods in the front and similar links in the rear. Try that first.
