Armada
- 5
- 0
- Buick City, MI
Maybe I missed it in the resource section, but do we have a TM for the 3kw diesel genset Mep-701a? (Mep-016b w/o ASK). Thanks
Ike,.....These units also will output 120V 1 phase, 240V 1 phase, 120/208 3 phase, and a special 120V only 3 phase mode, they however do not output household 120/240 split single phase unless you make a small modification....
I'm confused I thought 120/208 three phase was similar to what I learned as 240D:Mine does have the reconnection switch, options are 120V only, 240V only, 120/208 3 phase, and a 120V only 3 phase mode there is no 120/240 split phase option on these, however it is possible to get 120/240 split phase out of them by adding a single jumper wire while set in 240V single phase mode, of course bad things would happen if you changed the switch without removing this jumper. I have thought about doing the modification myself, but don't want to have to worry about load balancing a pair of 1.5 kw 120V legs.
Ike
